Why did I get the wrong label reflection
The setting was shown as the image above, I I didn;t get the result that I wanted, anybody knows the reason why?
I believe you need to change the “Depth” parameter in the label settings. 0 means infinite depth so it is visible through all the geometry. Try setting it to a small value where it still shows up at the surface where you want it.
Heine is 100% right, happens to me a lot as well and can be confusing. I think I would have preferred the default value of depth was a few mm. I think most of the time you don’t want labels to appear all over the same material and mirrored.
Wow, that’s really amazing, thanks, Heine.
Thanks, Oscar, you’re always so kind and helpful when I run into a problem.
